P0420 front or back sensor?
Old Oct 8, 2017 | 03:39 PM
Bpc576's Avatar
Default P0420 front or back sensor?
I noticed after seafoam test that there is a little tiny leak on the exhaust manifold gasket. but its small. Im running a big downpipe 3 inch on my s40. is the 420 code for the front or back? ive looked it up and people have been saying both.. 2000 s40
Old Oct 11, 2017 | 04:46 PM
the P0420 code is measuring catalytic converter efficiency by looking for a delta between the two O2 sensors. When you look at how O2 sensors can fail, it can be due to a bad heater element or the sensing circuit. With that said, when you have an exhaust leak or a free flow exhaust, that can mess with the dynamics of the sensors. You may want to read up on what a Cel-Boss does - (ie removes the sensor from the direct airflow stream ). If you car is running reasonably well and you are sure you're cat is in good shape, that may be a quick trick to try.
froyal
Oct 21, 2011 05:47 PM
fioramosca
Oct 7, 2010 09:14 PM
HummerGuy
Nov 21, 2008 07:35 AM
mr maraki
Sep 3, 2008 09:21 PM
