pcv tube 05 s50 t5
Old Mar 22, 2008 | 12:17 AM
primodevil's Avatar
Default pcv tube 05 s50 t5
so i had some issues under the hood that sounded quite ominous... kinda squeely belt sound...thought it coulda been a bearing as well... but there is a damn tube made of the crappiest plastic known to man that goes up the side of the block(directly to the front if standing in front of the car)... it broke and made a wistling noise, dose any one know if i have to hve that part or can i possible create a hybrid pice using the to remaining pieses... the end that would connect to the pcv, and the end to the valve cover????
Old Mar 22, 2008 | 09:26 AM
Hudini's Avatar
Default RE: pcv tube 05 s50 t5
I would just splice in a good piece of vacuum hose. Careful that it can take both vacuum and boost and not collapse or blow off.
Wait till you change the headlights and the inner adjustable part breaks loose because the cheap a$$ plastic breaks. Nothing JB Weld can't handle but what a PITA having to disassemble the headlights to fix it.
Old Mar 22, 2008 | 10:29 PM
primodevil's Avatar
i ve changed the lights, its not too bad... just really differnt... go figure its a volvo
Old Mar 24, 2008 | 08:16 PM
Bigtrev's Avatar
I would take it to the dealer especially if it is under warranty. Volvo has updated the pcv (breather box) as well as made that plastic tube into a rubber hose. If not under warranty you can atleast buy the updated parts and install them yourself. You will need to remove the big air box in the front of the engine though.
Old Mar 25, 2008 | 08:29 AM
Hudini's Avatar
Ahhhh, warranty. That's what them there new fangle cars have. lol
Greg Z
Apr 7, 2014 02:02 PM
Tamen13
Aug 29, 2013 10:31 AM
xjflexer
Jun 16, 2012 11:43 AM
jrhall3k
Mar 6, 2011 07:12 PM
Beau98
Aug 16, 2010 10:10 PM
