Plug boots on 01
Old Feb 10, 2008 | 11:39 AM
BRB's Avatar
BRB
Default Plug boots on 01
I had a little trouble removing the plugs from our 2001 S40. The neoprene(?) boots at the end of the plastic plug connectors stayed stuck to the plugs when I pulled the ignition wires off plugs 1 & 2. I demolished one of the boots trying to tease it off with needle nose pliers. I was able to tease the second one off using a pick tool with a 90 degree bend in the end.
1) How important is this boot? Can I run without it?
2) Can I buy just the boots anywhere, or to I need to purchase the entire plug wire set? I had no luck locating them at myswedishparts.com or thevolvosite.com.
Here's the boot:
Old Feb 10, 2008 | 05:25 PM
Default RE: Plug boots on 01
I would buy a new set of wires.
Old Feb 11, 2008 | 06:55 AM
mcguij1's Avatar
you need a new set now.
Old Feb 11, 2008 | 08:23 AM
reg's Avatar
reg
When you reinstall the plugs, put a dab of copper paste on the plug threads so that the plugs will come out easily next time you want to change plugs. On the rubber boot, smear a bit of silicone (dielectric) paste inside it and they will be easily removed "the next time".
r.
Old Feb 16, 2008 | 07:57 PM
Hudini's Avatar
Old Mar 15, 2008 | 08:27 PM
BRB's Avatar
BRB
Belated update. I drove the car about 30 miles with the boot missing from the #1 plug. I'd get a noticable stubble and flashing check engine light upon deceleration. Otherwise the car ran okay. A new plug wire with its boot cured things.
I use Anti-Seeze on the plug threads and a good dose of silicone grease on the plug boots. We'll see how things come apart in another 30K.
zippinbye
Nov 23, 2012 08:53 PM
tomecsi
Nov 1, 2011 03:16 PM
02VolvoS40
Jan 10, 2011 04:04 PM
IsuzuFire
Jun 29, 2010 01:32 AM
Mikenem
Jan 12, 2010 05:04 PM
