PO 128 ENGINE CODE
Old Jan 18, 2009 | 11:53 AM
mrford55's Avatar
Default PO 128 ENGINE CODE
GOT A PO128 ENGINE CODE GAUGE READING GOOD LEVEL GOOD.MAYBE SENIOR ? 2001 S40.
Old Jan 18, 2009 | 01:16 PM
mrford55's Avatar
Default RE: PO 128 ENGINE CODE
and does any body know were the temp senior is.
Old Jan 18, 2009 | 02:58 PM
jrgillespie630's Avatar
From: Cincinnati, but somehow ended up in Milwaukee
Common thing to go out. Coolant temp sensor is located right next to the thermostat, almost underneath it. It's easy to change and I'd recommend changing the thermostat at the same time. Another post I've done has a pic to help you out. Get your parts from ipdusa.com best price and they are a sponsor on the forum. To change both parts it took me about 30 minutes.
Old Jan 18, 2009 | 03:14 PM
mrford55's Avatar
thanks is thermostat in lower hose
Old Jan 18, 2009 | 03:47 PM
The thermostat is in the Upper hose at the motor.
Old Jan 18, 2009 | 03:56 PM
mrford55's Avatar
coolant sensior there too
Old Jan 18, 2009 | 04:38 PM
Yes it is in the lower thermostat housing.
yeah, check my other post titled "coolant sensor" i think it's on page 3...and it will go through everything. I had the same problem a few weeks ago and TECH came to my rescue.
Old Jan 18, 2009 | 04:48 PM
mrford55's Avatar
THANKS GUYS
Elsid
Sep 9, 2010 08:42 AM
Sthacker70
Aug 21, 2009 08:50 PM
badmonkey
Jul 28, 2008 09:15 PM
TDolce
Sep 15, 2007 07:01 AM
gzh
Mar 21, 2007 09:29 PM
