power drop at 4000 rpm
No check engine light then no codes IIRC. How about revving by hand? The newer S40's have drive by wire throttle control so I'm thinking there may be a dead spot in the throttle control? Something similar to a dead spot in the throttle position sensor causing problems in cars with a throttle cable.
Also, have you looked to see if all the underhood piping is intact? A leak after the Mass Air Flow sensor could cause problems.
