Power Failure
Old Feb 3, 2017 | 10:11 AM
Matt Masiloane's Avatar
Default Power Failure
hey guys..i have a volvo s40 2.0T automatic when i drive and the engine runs hot it starts to fail like when i put more power on the pedal it keeps on cutting power. pls help.
Old Feb 3, 2017 | 02:10 PM
AutoNaut's Avatar
How hot is it getting?
Other than the running hot, I would guess spark plugs.
Old Feb 5, 2017 | 03:51 PM
does it happen after you've been driving a while (ie when the engine gets fully warmed up) or from the start? Does the car sound normal and is there a check engine light on? If you have the check engine light on, first step is to get the diagnostic codes read.
Old Mar 1, 2017 | 04:17 PM
Poliov's Avatar
I'm having the same issue. Can't pass cause it cuts out the power. I can shut the car off and restart after 30sec and its back to normal again... Till I put the pedal down!
Old Mar 2, 2017 | 06:14 AM
Hudini's Avatar
Smile
Start a new thread for your car and don't forget to give year and engine plus as much information as possible.
Old Mar 2, 2017 | 06:17 AM
Hudini's Avatar
Post
Do you have a check engine light?
How hot is hot? Like in the red on the gauge? Have you checked the coolant level?
What you describe could be several things from a bad fuel pressure sensor to a bad Turbo Control Valve or more things. Any additional information you could provide would be good.
jasonthaynes
Dec 2, 2012 05:32 PM
kosmoscanyon
Dec 16, 2008 12:39 PM
ace760turbo
Apr 24, 2006 08:40 PM
volvoz
Sep 4, 2005 01:39 AM
