Remote Lock / Alarm Problem
Old Nov 30, 2011 | 02:46 PM
DavidAR's Avatar
Default Remote Lock / Alarm Problem
2002 S40
I seem to have a problem with my remote lock and my alarm. Don't know if they are related.
When I lock the car using the remote, the lights do not flash. And I don't see any alarm indicator. Also, after letting it sit locked for about 5 min i reached in the open window and opened the door and the alarm didn't go off. The alarm does sound when you use the panic button.
Old Nov 30, 2011 | 03:23 PM
GerBeGurGya's Avatar
Iv heard the the contact at the hood lock can cause this problem.Basically its like the hood is open therefore the alarm doesnt engage.Check the microswitch maybe a good dose of wd-40 will solve your problems.Not sure tho as if the alarm should or shouldnt go off in case you open the door from inside.
Old Nov 30, 2011 | 04:11 PM
DavidAR's Avatar
I'll give it a try and let you know if it works.
Old Dec 1, 2011 | 03:51 PM
DavidAR's Avatar
Sadly, that did not work. I tried manually holding down the hood switch and that didn't work either.
Old Dec 2, 2011 | 12:07 AM
You have to measure if the switch works or not using a multimeter.Holding it by fingers is not different then when you close the hood.WD-40 also has to get inside of the switch cleaning it outside will not do it.
taj59
Jul 17, 2014 08:37 AM
abc05
Feb 2, 2010 05:10 AM
shergar76
Jan 6, 2009 07:40 PM
TomInTN
Nov 9, 2008 05:25 PM
ausman007
Jun 13, 2007 07:52 AM
