Replacing Fuel Pressure regulator on an S40
Old Apr 14, 2009 | 04:49 PM
cshutts's Avatar
Default Replacing Fuel Pressure regulator on an S40
Hi-
I have a 2000 S40 and the fuel pressure regulator is leaking. Is this an easy repair to do myself? Does anyone know how it attaches to the fuel rail?
Thanks
Old Apr 14, 2009 | 05:42 PM
sghokie's Avatar
I have a 2001 that I just replaced it.
I am not sure if I had the original regulator in it or not.
What I did was pull out the center piece which is metal by removing the clip.
Then got the part number off it which happened to be the same as the 2003-2004 FPR.
Then I just got that part. It was a bit of a hassle my first try when google searched the part number then ordered it, I made the mistake of saying I had a 2001, the supplier above all motor works refused to send it to me saying it was the wrong one for a 2001. Despite my emails insisting they send it they just canceled the order. I ended up getting one locally and putting it in. Takes only about 5 mins to do.
Old Apr 15, 2009 | 10:46 PM
cshutts's Avatar
thanks for the info. I just bought the whole part, for $175.
I will give it a shot...
Chris
Old Apr 23, 2009 | 10:50 AM
mrford55's Avatar
were is the fuel reg mounted on a 2001 s40
Old Apr 29, 2009 | 10:54 AM
mrford55's Avatar
Smile Replacing Fuel Pressure regulator on an S40
were is the fuel regulator on a 2001 s40
Old Apr 29, 2009 | 05:02 PM
sghokie's Avatar
under the black plastic cover right in the front on the right side of the engine.
MntnDewMan
Apr 3, 2024 04:05 PM
NYs40turbo
Jun 8, 2013 03:25 PM
slsnumber1
Mar 15, 2011 02:55 PM
hoffmandirt
Jan 24, 2010 06:25 PM
IdleTime
May 29, 2008 04:01 PM
