Rough Idle/Stumbling Acceleration
Old Jul 10, 2019 | 05:43 PM
npapz34's Avatar
Question Rough Idle/Stumbling Acceleration
Girlfriend's 2003 S40 1.9T with 82K, I'm getting a misfire at idle and a slight stumble on acceleration. I now have these codes : P0403 and P0442. The gas cap was replaced recently. I had a P0172 but that was fixed with a new MAS and an exhaust purge valve. I changed the spark plugs (NGK iridiums)and cleaned the throttle body when I serviced it last. I'm not getting any misfire codes. Does anybody have an idea of what I'm missing? I'm new to Volvos. Thank you in advance!
Old Jul 10, 2019 | 08:59 PM
the P0403 points to the "EGR control circuit" and the P0442 points to a leak in the evap system. Sounds like either or both has created a vacuum leak. The P0442 can be caused by the vacuum line going all the way bay to the evap cannister (by the passenger rear tier) - that's probably what I'd look at first. You may need to do a smoke test to find it - google "J Tube Volvo" for some ideas.
Familys60guy
Apr 24, 2023 11:14 AM
bm97
Jul 8, 2018 09:05 PM
kpwkaw@gmail.com
Jul 1, 2011 04:38 AM
cbevis
Apr 5, 2010 10:58 AM
rosesforlily
Nov 5, 2009 09:23 AM
