S-40 oil leak
Old Apr 21, 2013 | 09:37 AM
mrford55's Avatar
Default S-40 oil leak
Got a 2002 s40. Just got a oil leak from timing belt area.has any body seen this before.
Old Apr 21, 2013 | 10:02 AM
migbro's Avatar
Yes. Probably the VVT pulley. Less likely - camshaft seal.
Old Apr 22, 2013 | 02:41 PM
1998v70's Avatar
my 2000 has a small leak from the crankshaft front seal.
Old Apr 24, 2013 | 07:01 PM
Hudini's Avatar
Yes, it is a well known issue. There are a couple areas to look for leak mainly. The seals behind the CVVT gear on the exhaust cam and the regular gear on the intake cam, the little "plunger" looking thing on the CVVT itself, and the crank gear seal. If you notice oil on top of the engine look for a cracked gasket on the oil fill cap, a clogged up PCV system, or maybe the CVVT solenoid leaking.
Read this thread for more details:
https://volvoforums.com/forum/volvo-...acement-65973/
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
