S40 1.6d 2010 problem
Old Mar 29, 2017 | 08:00 AM
Willismg01's Avatar
Default S40 1.6d 2010 problem
Hi guys
Any help will be appreciated as I'm running out of ideas. I have a 2010 s40 1.6d2 that had an egr problem this week I have bought a new complete unit egr valve and Cooler. After the new pats where fitted the car still went into reduced performance mode I noticed next to the egr that is an electronic valve there is like an actuator that open and closes the egr by vacuum I took the pipe of and there is no vacuum what so ever so the egr will not open or close. So today I went and got 2 new vacuum solenoids that have now been fitted.one under the egr unit next to the starter motor and the one that is connected to the turbo actuator. Still same problem and same fault code p042e egr stuck open any help will be much appreciated thanks
steve
Old May 24, 2017 | 11:11 AM
Tyrone Stuart Lumby's Avatar
Default I have the same problem with the same car
Originally Posted by Willismg01
Hi guys
steve
Did you find a solution to this problem? I have changed the dpfe sensor and egr valve. At my wits end with this issue. Any advice would be great help.
Old May 30, 2017 | 06:49 AM
Hudini's Avatar
I'd suggest looking at the Volvo UK forum. There were no diesel versions in North America.
vovlo355
May 13, 2011 08:27 AM
Jedi
Sep 13, 2010 03:28 PM
Mro111
Sep 7, 2010 02:26 PM
Franconemo
Jun 6, 2010 05:32 PM
stream41
May 10, 2010 11:13 PM
