s40 2005 model side light replacement ?????
Old Apr 2, 2012 | 01:54 PM
Robbie1067's Avatar
Default s40 2005 model side light replacement ?????
hi all
just bought a 2005 s40 2005 2.0l diesel and need to replace the small side light bulb.
had a look under the bonnet and realised that there is all sorts of stuff behind the head light cluster is there an easier way to change the bulb without removing all this equipment ???
i look forward to ant help
cheers robbie
Old Apr 2, 2012 | 03:49 PM
Mad Matt's Avatar
Yes, there is a very easy way to replace the bulb. You just remove the headlight.
It's actually designed with the intention of removing it to replace bulbs.
See the little metal tab that's circled. All you have to do is pull up on it to remove the locking pin and the headlight slides right out.
You may have to disconnect the wires connected to the headlight but it's a just a clip that comes off easy enough.
Old Apr 3, 2012 | 02:16 PM
Robbie1067's Avatar
That's amazing changed both side light bulbs in less than 10 minutes plus changed them to LED's at the same time many thanks Mad Mat they look great
everritte
Aug 3, 2011 10:16 PM
fieser23
Jul 28, 2011 06:03 PM
Gymsey
Feb 23, 2010 01:35 PM
Qamar
Nov 14, 2005 12:53 AM
Qamar
Sep 27, 2005 03:19 AM
