s40 2006 Hooke up battery backwards now won’t start
Old Oct 30, 2020 | 08:33 PM
california77's Avatar
Default s40 2006 Hooked up battery backwards now won’t start
A friend hooked up my battery with negative polarity and blew 4 different fuses replaced all fuses but now just get a click when attempting to start. Do you think it’s a relay how should I diagnose further any help appreciated
Old Oct 31, 2020 | 12:55 AM
habbyguy's Avatar
Oof... that can do a LOT of damage. There are a lot of sensitive electronics / computers in a modern vehicle, and they don't do well when they're hooked up backwards. It could have fried a lot of different things. I would start by checking every fuse in the vehicle. Beyond that, I'd try to hook up an OBD reader to see if it's trying to tell you anything.
But be prepared for a long, ugly process to try to get it corrected. It could have literally totaled the car.
Old Nov 1, 2020 | 08:58 PM
GerBeGurGya's Avatar
I dont know how it is even possible given that the clamps are different in diameter for exactly this reason.
Old Nov 2, 2020 | 01:51 PM
perhaps they were using jumper cables. That said, OP needs to check all fuses (some may not be in the main box), relays and look for burnt wires. Some models also have a fuse on the power lead to the starter that should be checked. Sounds like the starter solenoid is clicking which says its getting some power, so its possible they now have a flat battery.
Old Nov 4, 2020 | 03:41 PM
Hudini's Avatar
It does sound like a bad battery. Clicking usually means low voltage reaching the starter solenoid. Check your battery voltage while trying to start it. If it drops to 8 or 9ish volts then the battery is low. If it stays 11-12ish volts then check the battery cables for continuity and resistance.
Bill Pol
Nov 22, 2022 08:39 AM
svantonder
Dec 28, 2018 07:24 AM
pattirose
Sep 26, 2018 11:01 AM
Myamma
Oct 5, 2010 08:57 PM
Maxplayer14
Jan 7, 2009 08:07 AM
