S40 - Changing the Timing Belt
Old Aug 19, 2005 | 12:09 AM
edgoss's Avatar
Default S40 - Changing the Timing Belt
Has anyone changed their own timing belt? I have a 2001 S40 and do
most of my own work. Someone told me there is some kind of oil switch attached to the cam and
if not set right will cause the engine light to come on. Is this true?
Should I try this or go to the dealer? Anyone know what they charge for that?
Thanks,
Ed
Old Aug 19, 2005 | 12:20 AM
Default RE: S40 - Changing the Timing Belt
Best advise I can give you is to make sure you have a CAM LOCK tool to hold the cams.Make sure the marks are lined up perfectly and you will be fine.
WolfPlayer
Apr 22, 2011 09:39 PM
qstyle
Mar 17, 2011 11:15 AM
dads 740 turbo
Nov 6, 2008 07:50 AM
thejman
Apr 8, 2007 04:33 PM
KINGI5T850
Apr 3, 2006 09:14 PM
