S40 Check Engine Light
Old Oct 26, 2005 | 12:53 PM
plynhrd117's Avatar
Default S40 Check Engine Light
I have a 2000 Volvo S40. I have had it almost two years, and it has spent at least 6months of those two years in the shop. The check engine light comes on atleast once a month if not more than that. I have taken it to the dealership where I purchased it and they can never seem to find out what the problem is. Sometimes it drives fine, sometimes it very rough and won't start. The light just came on again last night, and I just got it out of the shop about 4 weeks ago. They said a hose had come off and that's what caused the light to come on last time. It's got a little over 72,000 miles on it, and it only have 32,000 on it when I bought it in November of 2003. Any ideas of what I should do? I have had to put thousands of dollars into this thing, and it's always giving me problems. Anyone else have the same problem?
Old Oct 26, 2005 | 08:58 PM
Default RE: S40 Check Engine Light
Has it had all the software upgrades done to it?
Do you know what the codes are that the dealer pulled?
Old Oct 27, 2005 | 01:45 AM
fire2havoc's Avatar
A disconnected hose? I would get this checked out ASAP to make sure that there are no harmful gas leaks. You can take it to AutoZone and they will run the codes for you as well. It may also be a sensor problem and those are fairly expensive to replace (around $1,000). I also have the check engine come on periodically. However, my problem is not serious. I would confirm this with your car. The bottom line is that if you're experiencing constant problems and the car is spending much time in the shop - sell it. It should be saying that it's time to part with this Volvo and look for another.
Old Oct 27, 2005 | 11:17 AM
plynhrd117's Avatar
The dealer says that it has all of the most current software upgrades. I am taking it to AutoZone today to have them read the codes...will let you know what comes up. Thanks for your help!
Old Nov 7, 2005 | 02:25 PM
VolvoTechCMC's Avatar
Autozone codes will most likely not be the same codes as the Volvo PC will have. Or will they, in my experiences they wont.
ORIGINAL: plynhrd117
Old Nov 7, 2005 | 08:22 PM
fire2havoc's Avatar
Do they have the same ODBII readers?
Old Nov 8, 2005 | 01:10 AM
With our Actual PC we can look at alot of different stuff that a normal OBDII Scanner cant.........
Old Nov 8, 2005 | 01:21 AM
The info that can be accessed is AWESOME.
The P codes give a general Idea of the problem.There is differences between the p codes and the Volvo codes. I have seen some that don't even match at all.
Old Nov 28, 2005 | 11:58 PM
S Forty208's Avatar
I know you may have done this, but when my check engine light came on I went thorugh all of the caps and dipsticks to make sure they were tight. I found the transmission fluid dip stick to not be pushed in all the way. I pushed it tight and the light went off. Obviously that was a quick fix, but my not be your problem.
Old Nov 30, 2005 | 06:12 PM
dark_rex's Avatar
go to autozone and get the obd2 codes pulled for free. post them up here, and people will be able to help you. without those codes, everyone will be guessing.
dR
Old Dec 12, 2005 | 12:54 PM
annie's Avatar
check engine light has been on on mine for the last 7 months VOLVO store stated that very common on these cars something about sensors being too sensitive??had a complete check on my car and they found nothing
tngreg
Sep 5, 2022 07:27 PM
ori
Mar 24, 2011 11:41 AM
ErnstlS90
Oct 23, 2008 08:37 AM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
