S40 issues!
Old Nov 23, 2009 | 07:33 PM
TANK's Avatar
Unhappy S40 issues!
I have a 2001 S40 Turbo (138K) and I hear a repeating noise in the left front wheel area, it started when i would turn left and now it does it at 60 mph and at random times.
And when I go to start the car, it turns over 3-4 times before idle.
Can you offer any suggestions? Thanks, TANK
Old Nov 25, 2009 | 02:31 PM
Lyonsroar's Avatar
Moved to S40 chat.
Please post in the correct sub-forum next time.
Please read this. I believe you will find your starting answer in here:
https://volvoforums.com/forum/volvo-s40-11/frequently-asked-questions-34712/
Old Nov 25, 2009 | 10:15 PM
AutoNaut's Avatar
Can you describe the noise?
Clicking may be the CV joint. Moaning or howling may be a wheel bearing.
Stan
Old Nov 26, 2009 | 10:56 AM
MADMAN36's Avatar
sounds like a CV...I am in the process of replacing mine. It had progressed much father than the clicking.
Old Dec 3, 2009 | 12:35 PM
jackposter379's Avatar
I have a similiar sound underneath the brake/peddle area. What is CV?
Old Dec 3, 2009 | 10:17 PM
AutoNaut's Avatar
CV = Constant Velocity Joint
http://en.wikipedia.org/wiki/Constant-velocity_joint
Old Dec 4, 2009 | 07:26 AM
lovely09's Avatar
You might have your brakes checked.Once the pads start to wear out they are designed to make a similar noise to alert you that they need to be changed.
webeckers
Sep 14, 2008 05:03 AM
hocbj23
May 21, 2007 09:05 AM
Nohelmet
Apr 5, 2007 02:39 AM
Tupolev22m
Sep 12, 2006 02:27 AM
