S40 Locking system and fobs issue
Old Jan 4, 2022 | 06:19 PM
Goran Nau's Avatar
Default S40 Locking system and fobs issue
Hi Guys , l just got this car recently Volvo S40 2008 and both of key fobs wont lock or unlock the doors … l am using the key manually to open the car but only driver seats door opens the other doors remain locked. l checked the battery on the fobs replaced them that didn’t work too tried to contact some of the local locksmiths for a help they all redirected me to the Volvo car dealer l called them and just for a check because the car is out of warranty will cost 230$ … did anyone had similar experience with locking system ?! Any help is appreciated Thanks
Old Jan 6, 2022 | 10:22 AM
richardkonrad's Avatar
Yes the manual only opens the driver side , which normaly activates the alarm until you put the key into the ignition , if that does not hapen then its probably the receiver that has failed , agents only from what I know ,and costly , if you are ok with that and the car drives fine its up to you
Old Jan 7, 2022 | 07:59 PM
Goran Nau's Avatar
Thanks tor the reply!
yes its opens the drivers door manually l think my car does not have any alarm … l am using the key manually atm to open and close doors etc and l dont have any issue with starting the car etc … main key and spare key both not working just with the doors ….
Old Jan 10, 2022 | 07:54 AM
Long shot but have you checked the voltage on the 'new batteries? should be at least 3.4 volts for a battery I one replaced a remote battery with a new one and it also did not work , the so called new battery was 2.9 v
Old Nov 12, 2022 | 11:32 AM
VolvoSA76's Avatar
did you manage to fix this issue, I have the same problem
1998v70
Aug 16, 2015 09:13 AM
buddlejr
Dec 3, 2012 06:08 AM
tallrob
Aug 14, 2012 12:03 PM
mmnewcomb
Apr 27, 2011 08:28 AM
edgey99
Jul 28, 2009 12:48 AM
