S40 T5 power steering leak
Hi all have not been around for a long time (about 5 years!) our volvo has developed a leak in the steering rack , the fluid is very dark and probably needs replacing as its 15 years old , its a spare car now as selling it was not worth it in my country (we fortunately have lots of space ) has anyone tried the various stop leak additives or should I just have it fixed? I assume the rack will have to come out and will be quite costly . vehicle has 126k on or around 80 000 miles on . If an additive will work then I assume I must first replace the fluid.
A lot depends on just how bad the rack is leaking. I never had to mess with the rack on my V50, but don't recall it looking all THAT difficult. But yeah, it wouldn't be a bad idea to flush the old fluid, and then add some PS stop leak (can't tell you which works best - I'd recommend perusing the feedback on Amazon, especially those who mention "Volvo" in their feedback). This isn't what I'd do for a car that I was planning on driving another 100,000 miles, but is a sensible thing to attempt on a vehicle that's coasting its way to the boneyard currently. ;-)
The leak is from the steering rack driver (right) side , I do most work on my older cars (regular service, brakes etc) , I can remove the rack but dont have the expertise to service it , I will try the stop leak with a flush and if that does not work will probably take it out and have it serviced
richardkonrad (01-19-2021)
Well a few days later and unfortunately the leak is back , it seem to stop for a while but obviously the bottle fix is no good , I got a good quote to fix it including removal so will do that as the monies saved by removing myself is not worth it and the guarantee then falls away , the cost is about 300 us from a steering specialist
I took the car to the specialist and left it there for 2 days , they contacted me to say there is no leak , they removed the boots and all dry , I told them I changed the fluid and added stop leak , they said that it must be purged as the stop leak can block pipes , so now a few weeks later and all fine after using it daily , so will just continue to use it and see ,cost was minimal
Richard, did you clean out the fluid from the bellows at the end of the leaking rack? If not, the fluid that's stuck there will continue to leak, even if you've "fixed" the rack with an additive (which is very possible, BTW - if only temporarily, whether that means two weeks or five years).
