Sporadic Transmission Issue
Old Mar 25, 2012 | 07:10 PM
rocketarm09's Avatar
Default Sporadic Transmission Issue
Hi,
I was hoping for some advice on my 2006 s40 T5 AWD. I bought it in December with 83,000 miles on it and only a couple weeks later started noticing a “kick” when shifting from 1st to 2nd gear. This kick would also occur when going from a stop to a start and also occasionally when slowing down I would feel a sort of trembling of the car. I went and had the transmission fluid replaced, had the control arms replaced, and had the front left axle replaced. The guy who did the axle said that the right one was loose and moving but I did not have that replaced yet.
The interesting thing is that is problem is very sporadic. Many times I wont get the kicking at all and the car drives perfectly and other times it will start off perfectly but then kick in at some point during stop and go driving. The car has no issue on the highway. Also I have never had a check engine light kick on. Any advice or people have a similar situation? THANKS!
Old Mar 26, 2012 | 08:33 AM
Sometimes the transmission mount will cause hard shifting. That is pretty cheap and easy to replace.
Old Mar 26, 2012 | 09:18 AM
Thanks! Unfortunately I already had the transmission mount checked and the guy said it was fine. Any other alternatives?
tareyazo
Nov 3, 2012 11:22 AM
pennjam1
Mar 11, 2012 05:54 AM
tpf
Oct 25, 2009 10:06 PM
zmontgomery
Mar 23, 2009 11:26 PM
glewis1
Dec 15, 2008 03:09 PM
