SRS Airbag Warning
Old Jun 7, 2017 | 08:55 AM
Ryan339's Avatar
Default SRS Airbag Warning
So I accidentally forgot to plug the sensor back in under the passenger seat when I had the carpets out. With that sensor unplugged I started the car and now the SRS Airbag Warning is on the dash.
Does that sensor trigger that Warning? And if so how do I get rid of it? I left the battery unhooked all night and that didn't help. Any suggestions would be huge!
Old Jun 7, 2017 | 02:09 PM
Yes, a disconnected sensor will set off the SRS fault code. Its stored in the computer so you need to find a scanner that can view and clear the code. Not all OBD2 scanners can view/clear SRS codes so research if you plan on buying or renting one. I bet a friendly Volvo dealer would clear the code for you if you simply explain you were doing some cleaning and forgot to reconnect the sensor.
Old Jun 7, 2017 | 02:10 PM
Ryan339's Avatar
Very good! Thanks.
majer
Oct 17, 2016 10:22 AM
hotwls13
Jan 4, 2014 02:15 PM
Sir Vivor
Jan 15, 2013 09:00 AM
ROBLU540
Feb 12, 2008 07:05 PM
mavman
Mar 12, 2007 09:02 PM
