Starting Issues
Old Dec 26, 2008 | 01:37 AM
wonderyak's Avatar
Default Starting Issues
Hello,
I just bought a 2002 S40 (1.9L Turbo) a few weeks ago after my 99 Malibu was totaled. The car runs great, is a great pleasure to drive and is all around wonderful (I've wanted a Volvo since I was a little kid). This morning, and again later this evening I had an issue starting the car.
Power is fine, the ignition seems ok, the only way I could get the car to turn over was by giving it some gas when I turned the key (one startup in between the two bad ones was just fine).
The car was/is in great condition with 55k miles when I bought it.
Any ideas? Spark plug? Fuel throttle?
Old Dec 26, 2008 | 08:43 AM
Default RE: Starting Issues
You might have a bad fuel pressure regulator. It will bleed the fuel pressure down to 0 after sitting for a little while. Then it will crank for a while to start.
Old Dec 26, 2008 | 01:50 PM
djalmab's Avatar
Is there any way to check the fuel pressure after the car has been sitting for a while ?
Old Dec 26, 2008 | 02:38 PM
wonderyak's Avatar
Is that something I can test/fix myself?
Will this lead to/cause any other issues besides the starting problem?
Old Dec 26, 2008 | 05:42 PM
No it usually only causes the hard start.
Easiest way to check is to pull the vacuum line off the regulator after is has been sitting a little while and see if there is fuel in the vacuum line. If there is it is bad.
burtonsnowbird
Feb 11, 2006 05:02 PM
burtonsnowbird
Feb 7, 2006 01:07 AM
splash114
Jan 29, 2006 10:36 AM
PhilM
Jan 23, 2006 04:21 PM
