starting problems
Old May 15, 2008 | 01:18 AM
lalo's Avatar
Default starting problems
i have a 2000 s40 and when you go to start it must crank like for 5 to 7 sec. before it starts. if i go to the store turn it off then get back in like in 5 min go to start it does it again. if i turn it off and wait like a minute it starts back up perfect. ive changed the fuel cap has new wires new belt new timing belt new oil and hasnot giving me an error code. car runs really good it kinda lags a bit when you romp on it from start but then it gets going. do you have anything on this please help.
Old May 15, 2008 | 05:26 PM
ianparsons's Avatar
Default RE: starting problems
I also have 2000 S40 1.8 XS.
Easy to stall when first starting up in the morning. Could it be spark plugs or the fuel line??
Mine sounds as if it struggles once you get to 80mph. That pushes just over 3500 revs. Can't imagine getting the 124mph top speed out of it!
How high revs should you take it in 2nd and 3rd gears when changing up - 4000+??
I want to drive it well and take advantage of 122bhp but dont want to damage the engine.
Old May 22, 2008 | 06:05 PM
nandrolone's Avatar
Fuel pressure regulator?
Tech?
Old Jun 5, 2008 | 02:44 AM
i0013701211's Avatar
I'm having this problem too..It's been going on for a couple weeks. Any suggestions?
Old Jun 5, 2008 | 07:49 AM
mcguij1's Avatar
these sort of posts come once a month...9 times outta 10 its the fuel pressure regulator...
VolvoLisa
Mar 22, 2005 01:48 AM
bigb1rd
Mar 1, 2005 09:59 AM
bccb037
Dec 29, 2004 04:42 PM
rl92821
Feb 1, 2004 12:54 PM
