Steering Wheel Problem
Old Oct 2, 2018 | 01:08 AM
Lone3wolf's Avatar
Default Steering Wheel Problem
One day the steering wheel on my 2003 Volvo s40 became really hard to turn and began to squeak. I also began to notice little cylinder shaped pieces of metal on the mat under the steering wheel. (I’m guessing they’re falling from something inside the steering wheel). Does anyone know what it could be?
Old Oct 2, 2018 | 07:38 AM
pierremcalpine's Avatar
That's pretty odd. I would recommend taking off the top and bottom plastic covers on the steering wheel base to see if that gives you some more info. Three Phillips screws from underneath and pull the bottom part off and then pull the top part off being careful to work around the ignition cylinder.
Old Oct 2, 2018 | 10:42 AM
habbyguy's Avatar
I've yet to have to do much in that area, but it sure sounds like a roller bearing has failed (the bearings in a roller bearing are small, silver cylinders). I'm betting that if you contort yourself enough to be able to look up at the steering column (after removing the dash panels underneath the driver's side dashboard), you'll see some "unusual" play in the column as you crank it back and forth, and that the source of those rollers will be obvious.
C30d5
Volvo C30
Aug 4, 2017 02:34 PM
mshahzad
Dec 19, 2015 03:54 PM
S40 in Fla
Interior
Aug 20, 2013 08:45 PM
kapka42
Jul 20, 2011 08:05 PM
dogwillhunt
Sep 26, 2008 06:46 PM
