Still steering wheel
Old Dec 31, 2016 | 12:33 PM
MaxDec's Avatar
Default Stiff steering wheel
*Stiff
2001 Volvo S40. 80K miles. Steering wheel is stiff. When turning from a stop light car feels heavy to turn. There is a little bit of groaning noise when turning. The PS pump sounds normal when stopped. In the manual it recommends ATF fluid. Bought Sea Foam lube tune yesterday and put some in the reservoir to clean the system out yesterday and then drained and filled the reservoir with Mobile 1 ATF. It didn't make a difference. There are no visible leaks in the PS system. How can I be sure its not the pump that is causing the issue?
Old Jan 4, 2017 | 12:10 PM
Hudini's Avatar
Place the front of the car up on jackstands and have someone turn the wheels with the engine running to see if it still groans and if it gets easier to turn. I'm betting it's the pump though as steering racks tend to get loose and leak fluid. Other components that can fail are the strut bearings up top and ball joints at the bottom.
Old Jan 8, 2017 | 07:44 AM
MaxDec's Avatar
Ya it does groan. No other leaks. I have concluded its the pump but now I have more pressing matters with the car. Will change the pump eventually.
trainlover
Mar 16, 2014 08:48 AM
RJSV70
2001-2013 model year V70
15
Oct 26, 2013 06:05 AM
nehopsa
Jun 24, 2008 11:20 AM
katiejoyful
Dec 12, 2007 04:49 PM
JeremyR
Aug 3, 2006 05:36 PM
