Temperature Control on 2009 S40
Old May 26, 2010 | 01:38 PM
hammer1234's Avatar
Default Temperature Control on 2009 S40
I have a 2009 S40 with close to 15K miles, and it has treated me pretty well so far...
Over the last few warm days here in Massachusetts (90+ degrees), however, I've noticed that the A/C isn't blowing very hard even though I have the temperature control set to 66 degrees. The air coming out seems to be cool enough but it's just not blowing that hard. I'd think that the system would be blowing out harder to try to reach that temperature.
Is this something that others have seen in the 2004.5 and later models?
Old May 26, 2010 | 09:48 PM
isaac49's Avatar
My 2006 AC works great. I'd say get yours looked at.
Old May 27, 2010 | 12:43 PM
SVTfocusO3's Avatar
or is this about blower control???
Make sure it only blows out the center vents, not floor or defrost. Recirc button helps, other than that, dealer.
Is the last six of your VIN higher or lower than this???
461033
Old May 27, 2010 | 06:29 PM
hammer1234's Avatar
461033
The car has ECC and the blower isn't blowing out hard enough to bring the temperature down to what I have it set to.
I can blast the fan no problem when I'm not in auto mode, and the air conditioner is cooling down the air just fine.
The last six of the VIN is lower than 461033.
Old May 28, 2010 | 08:05 AM
SVTfocusO3's Avatar
ok, so your in auto mode in the above situation, sounds normal.
temp sensor is behind the center stack in the panel you will see 3 marks in this panel, maybe heat it up or something and see if it changes speeds???
Old May 28, 2010 | 08:24 AM
hammer1234's Avatar
Just curious...how is the operation different above and below the VIN mentioned?
I spotted where the sensor is located. I can try some stuff but the car's going in for its 15K service within the next week or two and I'll have the dealer check it out then.
Old May 28, 2010 | 10:42 PM
SVTfocusO3's Avatar
Up to 2009 with that VIN, they have a problem with airflow coming out different places then set, you have it in auto, it goes where it wants to and controls the blower speed. If it did this not in auto, you may have a problem. If you want it cold, set it to LO, recirc ON, middle arrow.
ps
If you have a smell when first turning on the a/c, tell your dealer and they will treat it.
Old Jun 3, 2010 | 03:09 PM
hammer1234's Avatar
I think I figured out why the blower speed is lower...
I changed the auto fan speed under the climate control menu from High to Medium and forgot about it. Guess there is a base speed that the blower is at when the inside temperature isn't too much different from what it's set at.
Would have been nice to see this in the owner's manual...
Old Jun 9, 2010 | 02:39 AM
reojohn285's Avatar
First You have to checked it that The cooling system was being not as auto mode. If It was still in manual mode then checked the fan speed and also cooling speed. I am sure that You will get something else in that part.
jeang2000
May 8, 2013 05:48 AM
Fairy
Apr 1, 2013 10:09 PM
russmd
Nov 11, 2012 04:13 PM
AleCS
Sep 21, 2009 03:52 PM
S40goalie
Jul 30, 2009 07:20 PM
