Throttle body 2001 s40
Old Aug 6, 2016 | 10:51 AM
tommyb16's Avatar
Default Throttle body 2001 s40
Hi. I've had some issues with my 2001 s40 lately. It keeps stalling on me when I start it and I have to hit the gas to get the RPM's up and let it idle a little bit to warm up. Once I do that, the car runs fine. I'm getting the throttle body replaced and I'm hoping that doing so will correct the problem. My s40 has 148,000 miles and I hoping that it will run fine once I replace it. I just had the engine tuned up and an oil change.
I would appreciate it if anyone could help reassure me that replacing the throttle body should help. I'm not very good with cars and I want to make sure the problem will be corrected.
Thanks
Old Aug 6, 2016 | 04:30 PM
Smith Volvo's Avatar
Banned
Thanks
Check your idle air control valve hose that connects to the IAC valve from your charge cooler. Very common for these to get a hole in them and goof up your idle. It's a short - slightly 'S' shaped hose around 1" in diameter. It's a cheap part too!
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
shoter_hellas
Apr 10, 2011 09:17 PM
harstonsharley
Mar 7, 2006 01:09 AM
wavewright
Apr 9, 2005 06:15 PM
