ticking noise
hello. I just bought an 1999 s40 t4. I replaced oil filter, fuel pump, oil, timing belt, spark plugs and cables, and other things. I am concerned of a ticking noise my engine does. It is not the ticking noise it makes when i start the engine in cold that worries me, i know this sound is normal considering the lifters being charged. But sometimes after the car is already warm, it starts making a ticking noise in the engine, sounds like a lifter but i think it should not be normal cause the engine is already warm. I have read lots of forum to investigate what the problem could be. Since now i have the following options:
1. dirty lifters: at the volvo shop they tell me to performe a engine flush.
2. some problems with the o-rings: i quite do not understand this.
3. problem with oil pressure. BUt the oil signal does not turn on at any time.
I am concerned this ticking noise is caused by problems with the oil pressure. What can i do. I turn to the volvo dealer but they do not seem to take this sound seriosly, they say there is no risk of driving the car like this, but i have had some bad experiences and would not like to have one with my Volvo.
Please help!!
Please help!!
THKS!!! for your prompt response!!
What should i try first, the motor flush or replacing the o rings? Why does my engine oil indicator does not turn on if the oil pressure is failing? The ticking sound is not permanent, it begins but dissapears in about 3 minutes.
Volvo dealerships uses Mutol oil, but i hear Mobil 1 is much better. Which should i use? My car has 112,000km (about 60,000 miles).
