Transmission Performance Low
Old Aug 21, 2017 | 07:46 AM
s4kho's Avatar
Default Transmission Performance Low
Hello guys
Need your help/suggestion on below error message i receive
I have just repaired and overhauled my gearbox due to jerking & transmission slip 2 weeks ago.
Since then i keep receiving error message "transmission performance low"
i notice that the error will often come when i shift my gear from D to R. Once the error message pops i can't reverse the gear anymore even though it is in R position and forward gear stuck at #2.
Does anyone experience this before?
S40 2009 2.0 L
Thanks guys
Old Nov 11, 2017 | 08:53 AM
nchannon's Avatar
Originally Posted by s4kho
Hello guys
S40 2009 2.0 L
Thanks guys
hi I have the same model and year s40 and I got the same warning yesterday did you ever find out what was at fault
Old Jan 18, 2021 | 05:09 AM
florian_dum@yahoo.com's Avatar
Hi,
Did you find the solution for "Low performance transmission"?
S40 too
Thanks,
Florian Dumitru
Old Dec 12, 2022 | 12:09 PM
Bikanga's Avatar
Default Transmission performance low
Hello guys
S40 2009 2.0 L
Thanks guys
I drive volvo xc60 model 2014 my car started leaking under the gearbox when I took it to the mechanic he told me we needed to change a gearbox seal which we changed and I made gearbox serviced but when I was driving then it brought a message on the dashboard reading "transmission performance low" what could this be is it wrong gear box oil because I did not use the recommended DCT gear box oil.
Bikanga Muzamil
Uganda
Old Dec 12, 2022 | 01:41 PM
habbyguy's Avatar
Yes, if you used the wrong fluid, you can cause all sorts of problems.
Now the fun will be getting all of that wrong fluid out of the transmission and new fluid into it. About the only way to do that would be to disconnect the line that carries fluid TO the transmission fluid cooler, and run the engine long enough to drain out two quarts / liters of fluid, then put two quarts / liters of fluid back in, and repeat the process until only new fluid is coming out. That's going to take 10-12 quarts of fluid.
Old Dec 20, 2022 | 12:25 PM
+1, also make sure you follow the correct procedure for setting the fluid level. On most, there is a cold and warm line on the dipstick, fill to the cold line then do a driving cycle (google around but its like 15 minutes of mixed speeds ) then check the fill against the warm line to top off. Probably a youtube video available as well. Note on the six speeds that have a dual nut drain port, the inner nut removes the plug while leaving the drain tube that sets the level. You'd need a VIDA or similar scan tool to measure the transmission fluide temp, then set the level when its at 55C. Again there are vids to show you how (My VW DSG uses a similar drain tube design but the DSG gets filled from the top which requires removing the battery+tray!!)
Canadian940Turbo
Volvo C30
Aug 18, 2020 09:45 PM
mainesail
Oct 31, 2015 03:35 PM
cgreygoose
Mar 17, 2013 09:04 AM
Volvomac
Jul 14, 2009 09:08 PM
Marley1
Aug 30, 2006 09:18 PM
