trunk won't open
Old Apr 2, 2013 | 09:12 PM
kzabrisk's Avatar
Default trunk won't open
I have a 2000 S40 and the trunk won't open. I don't have the key fob, so I'm just trying to use the key and press the button on the trunk. After trying a bunch of different ways, I finally decided to crawl in the back and open from the inside. Surprise, there is no safety pull cord on this year/model I guess. So I removed the latch from the trunk lid and then removed the carpet from the underside of the trunk to see what was going on - (or not going on) The problem appears to be either a missing part or something became disconnected from something. (See pic)
The white, plastic triangle piece just in front of my middle finger (a cam of sorts) appears to have been attached to something on the end where the small amount of grease is located. But I can't tell where. When I rotate it, it doesn't seem to line up with anything to hook/attach to. This piece, when rotated downward, is what triggers the trunk latch to open. There's nothing loose in the trunk cavity that I can see unless it's wedged down in there somewhere... Any clues as to what/how is is supposed to be are appreciated.
Thanks!
Vincef
Mar 18, 2009 08:42 PM
sagi122
Feb 16, 2006 09:26 AM
midtown44
Nov 26, 2005 09:45 AM
nedflack
Dec 16, 2004 03:09 PM
