Tune Up ?
Tune Up ?
i have a 2002 volvo s40 1.9 litre engine
from canada, so it costs me approx 55 dollars to fill up and i get approx 500 kilmetres on a fillup, here where i live is 1.28 a litre
so really dont know what is my miles per gallon, bad at math
i want to get better milage,,,
few ?'s do you's belive in those additives you can add to the gas to get better fule milage or fuel injectin cleaner that you just add to the gas tank, do those work
for mthe volvo, what would you do for a tuneup,,spark plus, spark plug wires, rotor, air filter,,just changed my oil to synthetic,
i have 107,000 kilmetres
input really appreciated?
RE: Tune Up ?
thanks tech
reading the fuel injeCTION CLEANER bottle, cleans entire fuel system by removing harmful engine deposits from fuel injectors, intake valves and ports, intake manifold and combustion chambers, improves performance and fuel efficiency, reduces run on and elmates rough idling, safe for milti port injection systems and catalyic coverters,,,
it says to add 100 ml every other fill up
tech,,,will this some how trigger an engine light to come on....if using this fluid
should be safe to use, correct
thanks
thanks
