turn signal just went out
Old Feb 6, 2009 | 03:43 PM
dcjcdc's Avatar
Default turn signal just went out
HI
- just noticed my turn signal is not blinking,,,noticed the instrument panel on the dash that the turn signal is blinking faster,,,and the driver side front light signal is not flashing..even though i see the lights on,,but not flashing..tried the emergency idicator..and the front light is not flashing.....thinking it could be the bulb,,as i see two bulbs there..or maybe a fuse...thoughts anyone..what it could be
thanks
2002 s40 110,000kms
Old Feb 6, 2009 | 05:54 PM
dcjcdc's Avatar
Default adding
reading on the net
mentions possibly flasher relay to be replaced
thoughts anyone
thanks
Old Feb 6, 2009 | 10:56 PM
Sepp's Avatar
When I read your first post it sounded like you're having 2 different problems? or just one?
When the blinker "blinks" faster, it is the indicator of a blown lamp on that side.
When the blinkers don't work at all with these cars, (including the green indicators on the dash) usually if you turn on the flashers, it'll most of the time will get a sticky relay to work for a while..and that indicates a failing relay....
So, it sounds like you have a bad lamp, at least on the fast blinking side.
After you cycled the hazard lights, did you check the blinkers again?
Try that, and let us know how it works out.
Old Feb 7, 2009 | 07:10 AM
dcjcdc's Avatar
Default thanks for the response
tried the hazzard,,no luck
- yes when left turn signal is on, the green dashboard signal goes faster as well as the drivers side back lights rear siganl and the front left signal in the front is not flashing, the amber one...but when i just have my lights on, the amber light are on....so could it still be a blown bulb...even though there not flashing when signal is on,,but when running lights are on the light is on..
thanks
Old Feb 7, 2009 | 10:38 AM
Sepp's Avatar
Either there are two lamps are in the assy parking & blinkers, (I haven't looked yet) or the lamp is a dual filament (two lamps in one), and the blinker filament has burnt out. (new lamp is needed)
Old Feb 7, 2009 | 12:31 PM
Lyonsroar's Avatar
Replace the lamp!
It's easy to do and cheap!
Old Feb 8, 2009 | 08:26 AM
Sepp's Avatar
I finally had a look at mine, it's a single lamp (amber in colour), with twin filaments..So the blinker filament on your lamp is burnt out, but the other filament for the running light is still OK.
These lamps are available at any parts store, and it takes only a few minuets to change out.
Old Feb 8, 2009 | 09:53 AM
Lyonsroar's Avatar
Indeed!
Old Apr 10, 2010 | 02:02 PM
mierst's Avatar
the blinkers don't work at all volvo xc 90 2003
mmcolvin
Mar 29, 2013 12:41 AM
ded137t5r
Jan 12, 2012 10:59 AM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
Pfeiffer124
Feb 23, 2006 02:11 PM
