Upping the Boost!
Old Jul 19, 2007 | 12:43 PM
00 Silver S40's Avatar
Default Upping the Boost!
My 2000 Volvo S40 reads 9 pounds of boost after redoing the gauge for a better read. My question is how much boost can i raise it up to using stock internals SAFELY if its possible.
Old Jul 19, 2007 | 01:06 PM
S70driver's Avatar
Default RE: Upping the Boost!
15-17 PSI should do it. Anything higher and your out of the turbo effeciency range and potential damage to the car can be done. To be on the safe side I wouldn't run more then 14-15 PSI.
Also your ME7 and that means no MBC (Manual Boost Controllers) for you. To raise your boost you need an ECU upgrade.
Old Jul 20, 2007 | 06:20 AM
mcguij1's Avatar
woah, if your running a stock 12t turbo, dont push it past 12...especially if you have more miles on the turbo....
Old Jul 20, 2007 | 08:48 AM
S70driver's Avatar
ORIGINAL: mcguij1
I'm pretty sure it can hold 15PSI.
Old Jul 23, 2007 | 08:03 AM
mcguij1's Avatar
or you can listen to someone who drives an s70...im not standing by that...15 is a lot for a tiny 12t setup...its up to you...this is a nice forum site for basic volvo, if you went to s40concepts.net most of the guys there would tell you 12 is plentiful considering the factory maxes it at 8-9 psi....
Old Jul 23, 2007 | 08:28 AM
S70driver's Avatar
ORIGINAL: mcguij1
And a 13g isn't that much bigger then a 12t. And mine is running 15 no problem. I said 15 max no more.
Old Aug 20, 2007 | 11:48 PM
datastreamcom's Avatar
So you up the boost, how do you get more fuel, at the right mixture, in the cylinders?
Old Aug 25, 2007 | 11:20 AM
pearlrumdrum's Avatar
Im new, but your computer/ecu should take care of it, along with the MAF and what not it will detect more air comming in and in return it will throw more fuel in.
Old Aug 25, 2007 | 08:36 PM
my_volvo's Avatar
whats the best way to the speed of my s40 since its unfortunately not a T5.
thecheat
Sep 22, 2010 08:48 PM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
mygreenbomb
Feb 29, 2008 06:09 PM
blkwgnt5r
Mar 10, 2005 01:18 PM
