Vibration off the line can’t solve issue HELP PLS
Old Aug 1, 2020 | 05:48 PM
chefusa's Avatar
Default Vibration off the line can’t solve issue HELP PLS
2007 S40
new cv axels
tires good
proper alignment
front shocks and springs good
all steering gear good and tight
left and right motor mounts appear to be OK
runs great at cruising speed no issues at high-speed zero vibration only off the line does it vibrate
”has anyone experienced this annoying vibration?
any advice would be graciously appreciated
chef Mario
Old Aug 1, 2020 | 06:38 PM
Originally Posted by chefusa
2007 S40
new cv axels
What brand of axles did you use? Some of the new Chinese axles are worse than worn out ones.
Old Aug 1, 2020 | 06:39 PM
chefusa's Avatar
factory ome
Old Aug 2, 2020 | 02:29 PM
habbyguy's Avatar
My guess would be worn out compliance bushings on the lower control arm - those will let the geometry of the front end "wobble" under maximum power and torque, due to movement in the rear (donut) bushings.
Old Aug 2, 2020 | 05:58 PM
Hudini's Avatar
Sounds like what happened to my 2005 S40. Eventually it started making a metal on metal sound.
e. Thompson
Jan 30, 2016 11:28 PM
Sherry007
Apr 23, 2015 11:05 PM
swedes
Feb 16, 2014 04:16 PM
vfgilber
Dec 4, 2009 12:09 PM
ocean238
Apr 17, 2008 06:20 PM
