Volvo s40 2002 1.8 cold running problems
Old Mar 17, 2014 | 01:02 PM
Jfordy's Avatar
Default Volvo s40 2002 1.8 cold running problems
Hi guys
My volvo s40 seems to have a cold start problem. It will start and run but you need to keep revving the engine or it will cut out. It goes like this for about 10-15 minutes, until it is properly warmed up, and then runs fine. It also smells like it is running rich. The EML light comes on but then switches itself off. The RAC diagnostic machine states an O2 sensor AND crankshaft sensor. As these are expensive, and there are 3 02 sensors apparrently, I was wondering if anybody recognised the symptons and could help. If so, I would be eternally grateful, love the car but if i replace all these parts, it will cost a fortune! Please help if you can. Thanks
Old Mar 17, 2014 | 04:09 PM
difflock54's Avatar
Possibly a faulty ECT (engine coolant temperature sensor)
The thermostat could also be an issue.
The fuel mixture / air and timing self adjusts to the sensors directions and the ECM whilst engine cold and returns to normal after the normal engine running temperature is reached.
Check thermostat first as is the cheapest item.
Also check your coolant level as problems sometimes occur if the coolant level is below normal level range.
Dennis Bor
May 30, 2011 11:14 AM
rharveysr
Sep 12, 2010 09:05 PM
shamrock777
Aug 7, 2010 09:24 AM
erojo
Feb 22, 2009 06:55 PM
arttu
Feb 15, 2007 10:16 PM
