Volvo s40 2008 sluggish start
Old Nov 12, 2022 | 11:50 AM
VolvoSA76's Avatar
Default Volvo s40 2008 sluggish start
Hi I have a Volvo s40 2008 Iately after cranking, it has a sluggish idle and requires me to rev it before it idlea correctly, I have given a full service and even changed the fuel pressure sensor, but still no chnage.
Any help will be highly appreciated
Old Nov 12, 2022 | 12:41 PM
habbyguy's Avatar
Only about a million possibilities. You could start replacing part$$$$$ - but it's better if you scan the car for codes to see if it's trying to save you time and money by telling you where the problem is.
Old Nov 12, 2022 | 03:47 PM
VolvoSA76's Avatar
Thank you for your respond, but I have already sscanned it and there no codes that it gives, I am really out of ideas
Old Nov 12, 2022 | 08:59 PM
habbyguy's Avatar
Start with the usual suspects - new (quality brand from a trusted source) spark plugs, gapped properly, clean MAF and MAP sensors, look for vacuum leaks (maybe listen a telltale hiss with a hose as a stethoscope). Check the condition of the air filter.
Look up info on testing /.checking the PCV system.
Maybe clean the throttle body (could be gunked up).
I only left about 900,000 possibilities. ;-)
Old Nov 17, 2022 | 09:59 AM
VolvoSA76's Avatar
I have done it all, but still the issue persists
Old Nov 17, 2022 | 11:09 AM
have you checked fuel pressure with a gauge? low fuel pressure may be the pump or filter - not just the sensor. Have you checked compression? do you have access to a fully featured scanner that can monitor real time data?
Old Dec 5, 2022 | 11:47 AM
habbyguy's Avatar
Interesting that this guy seems to be posting only snippets from previous postings verbatim.
Old Dec 5, 2022 | 11:56 AM
Dingus1's Avatar
They also add numerous links to the end and eventually edit them out. Terrible advertising bot.
Old Dec 5, 2022 | 01:33 PM
As an option, you can report as spam any posts that contain blind links and the moderators can review/edit/delete and warn or suspend any offenders if need be.
Old Dec 7, 2022 | 05:24 AM
kitsapbeast's Avatar
Bad CEM
Hairtrigger
Nov 29, 2021 10:53 AM
Luisjeovanny
Jan 16, 2018 08:40 PM
Michael Lapinski
May 5, 2017 03:43 AM
trochefort
Jul 31, 2009 01:22 AM
msc78
Oct 7, 2008 10:00 AM
