volvo s40....Help
Old Jun 10, 2016 | 10:44 PM
sharonsmith's Avatar
Default volvo s40....Help
My volvo s 40 2003 model....is having issues....the key was stuck in the ignition....called volvo...bought new key...said it was the chip...got it back, installed it in the fob....tried the key....does not work...opens the locks, turns the car over ....does not engage the starter.....does not even attempt to....Help please....my only mode of transportation......
Old Jun 11, 2016 | 07:10 AM
ES6T's Avatar
It turns the car over but does not engage the starter? Those are the same thing..
Did you get the key programmed?
Old Jun 11, 2016 | 09:17 AM
Default Response
I bought the key from a volvo dealership....they told me it was just to be put in the fob....is that incorrect info?.....?
Old Jun 11, 2016 | 09:19 AM
Please treat me as a newbie....this volvo s40 is my 1st time owning one...love the car....but ....need advice desperately...
Old Jun 11, 2016 | 09:21 AM
ES6T's Avatar
Yes, that is incorrect. It needs to be programmed by them. They need the car there to do that.
I also doubt it was your problem with the key getting stuck
Old Jun 11, 2016 | 09:47 AM
Can you give me a more definitive answer....car is immobilized without key, and dealership is 100 miles away.....?....Do you have an idea?...What are suggestions....any will truly be appreciated.....any!
Old Jun 11, 2016 | 10:01 AM
ES6T's Avatar
I don't know how much more definitive I can be. The key needs to be programmed to the car. The car needs to be at the dealer for them to do that. Unless there is a mobile locksmith who does enough Volvo work that they bought the equipment to program Volvo keys, there is no way around it.
Old Jun 11, 2016 | 12:01 PM
Is it possible to bypass the ignition by installing a push button start?
Old Jun 11, 2016 | 12:16 PM
ES6T's Avatar
Not without a programmed key to read. And if you do that, anyone can steal the car very easily
Old Jun 12, 2016 | 01:15 PM
Hudini's Avatar
Does the old key turn all the way back to the off position? On my 2001 when the gear shift lever is placed in park, sometimes the pushbutton on the front of the gear shift lever does not pop out all the way. When this happens you cannot turn the key all the way back to off and the key remains stuck in the ignition. If you jiggle the gear shifter until the button pops back out then you can hear the solenoid release the ignition lock and the key will turn all the way back and can be removed. In my case I spray back inside the gear shift lever with WD40 or similar and it frees everything up for awhile.
ryanturbos40
Nov 24, 2014 06:28 PM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
