Volvo s40 Major service
Old Feb 16, 2015 | 06:15 AM
King Zoski Mapine III's Avatar
Default Volvo s40 Major service
i am driving a volvo s40, 2004 model, 2.4 and would like to perform a major service.....
what does the major service entails
Old Feb 16, 2015 | 04:52 PM
pkrface's Avatar
How many miles are on the car.
Old Feb 18, 2015 | 11:58 AM
you can plug in your miles here
https:// Auto Repair Advice, Car Reviews & Values - DriverSide
One thing I'd add - if you are not the original owner and don't have a full maintenance history to your car, you can either buy its Carfax ($40) to see if they did dealer maint or you can assume after warranty the owner simply did oil changes at Jiffy Lube...
FCP Euro is now coming out with more "kits" ie full set of tune up items so you can start there, then look at due dates for filters (oil, air, cabin, gas) and flushes - coolant, brakes, automatic transmission. If you flush the coolant, consider a new thermostat and overflow tank cap as part of the deal. Use the guide for appropriate inspections and lube points (ie door stops, cables etc) - visual check for leaks/spotting - engine, turbo, drive shafts. Visual check the brakes by pulling the wheels to look for rotor wear inside/out, pad thickness etc. Inspect various bushings for play/obvious signs of tears. This should be good for 30K miles or so. Most important is to know when the timing belt was changed last and is due next and inspect the drive belt(s) for the alt/pw steering/AC for both cracks/wear and tension - listen for idler noises..
asiantaylor
Jul 24, 2011 04:04 PM
angusjustice
Aug 30, 2010 12:03 PM
Hutson
Feb 2, 2010 08:56 PM
gordon368
Nov 17, 2005 11:54 PM
volvofanatic
Aug 20, 2005 06:07 PM
