Walking Timing belt
Old Oct 10, 2021 | 03:56 PM
KGWilder's Avatar
Default Walking Timing belt
Hi everyone I have a 2006 2.4 in a s40 and I just finished installing a new motor but the timing belt wants to work its way out and off the gears could this be a tensioner issue I've tried a new water pump new exhaust cam gear and 3 different tensioners and 2 new tensioner bolts and 2 new belts scared to start it would be fatal if it came off any suggestions would be so helpful thanks
Old Oct 10, 2021 | 07:37 PM
habbyguy's Avatar
The only thing that's going to cause that is if one of the pulleys isn't square with all the others. Double-triple-check your work. Did you use the cam position lock to install the belt?
And yes, starting it and losing the timing belt is game over for the engine, so get it sorted before trying to start it.
Newport_j
Jul 28, 2016 08:59 AM
240 DL noob
Mar 31, 2014 03:23 PM
akem21
1998-2000 model year V70
Nov 26, 2013 08:34 PM
MarkS60
Jul 25, 2012 03:31 PM
kc2mrg
Apr 30, 2012 09:38 PM
