Coolant fan will not shut off
Old Oct 1, 2021 | 01:29 PM
1redbullgirl's Avatar
Default Coolant fan will not shut off
2002 Volvo coolant fan will not shut off even if car is not running
Old Oct 11, 2021 | 10:32 AM
check the relay but could also be the fan motor. Search for other posts on this topic as it comes up from time to time.
Old Oct 11, 2021 | 11:30 AM
richardkonrad's Avatar
If the AC is on it will run until the temp is ok , so turn the AC off and see if it still runs all the time , does it eventualy stop? , its ok for fan to run a bit after switching off after heavy driving as it needs to keep the temperature contstant , but if it does not stop after say 2 minutes then its the temp sencor . when you start the car in the morning (car is cold) does the fan come on ?
Angry 04 S80
Feb 10, 2021 03:22 PM
aprotec58
Sep 7, 2011 01:07 PM
leonardd
Aug 6, 2011 06:48 PM
JLY198
Jul 13, 2011 08:50 PM
SAZALI
Oct 19, 2008 06:36 AM
