water
Common problem is the front sunroof drain tubes clogging up and coming loose.
Very poor design. There is a clear rubber hose that is number one to short. Number 2 does not fit properly into the rubber elbow that goes out of the car. I clean the rubber elbows and then reinstall the hose and use a zip tie to hold the hose into the elbow. This way it will not come loose again.
