Weird problem on s40 2001
Old Aug 4, 2016 | 07:51 AM
nacker's Avatar
Question Weird problem on s40 2001
Hello, i have a 1.8 2001 s40 with automatic transmission. Here is the problem:
While the car goes on the way(gear in D), when i release the gas pedal, sometimes engine acts like i put the transmision on 3 or L, its like engine braking. And rpm is waving. The car is fully normal on accelerate and stopping both gear in N and D.
I checked the shifter position sensor its ok.(Trying to start the engine while shifter isn't in N or P)
Do you have any idea?
(Sorry for bad language )
Old Aug 4, 2016 | 01:45 PM
Try rowing the shifter (Park to Lo to Park 20x) to see if that helps. Also check the transmission fluid level, then check color (wipe the dip stick on a white cloth or white paper towel). Anything else going on ie blinking shifter up arrow or tracs light on?
Old Aug 5, 2016 | 10:15 AM
nacker's Avatar
Transmission oil level is ok and color is nearly pink and there is no smell like burned oil.
There are no faulty lights on. Everything seems fine.
But i discovered today that when i turn off a/c, problem is noticable reduced. But i didn't had time to drive the car on a long range for testing. I am watching for an opportunity for it.
I will try rowing the shifter.
And thank you for reply.
swiftjustice44
Oct 25, 2012 06:32 AM
hohoho43
Sep 15, 2007 11:27 AM
vfl_guy
Nov 22, 2006 08:54 PM
hohoho43
Nov 2, 2006 10:08 PM
impsuper
Dec 13, 2005 07:05 AM
