2001 S60 Weird Noise in Compartment
Old Sep 3, 2007 | 01:10 AM
hohoho43's Avatar
Default 2001 S60 Weird Noise in Compartment
Hi,
I have a 2001 S60 2.4T, I noticed there was noise from the compartment, whenever I step the brake, the "squeezing" noise come back. It sounds like from the fan, because when I turned off the A/C or Fan, it stops, or when I turned the fan high, run fast, the noise gone. Can anyone please let me know what cause that? It is really annoying. I changed the cabin filter, it doesn't help. Is there a fan inside the compartment?
THANKS!
Old Sep 3, 2007 | 09:20 AM
Default RE: 2001 S60 Weird Noise in Compartment
Does it sound like a vaccum leak?
Old Sep 4, 2007 | 01:48 AM
hohoho43's Avatar
no, it doesn't.....it;s more like rattling.....it seems like when i get a bump on the road, it starts coming back......it's really annoying....
Old Sep 4, 2007 | 05:17 PM
Is the A/C draining under the car good?
Old Sep 5, 2007 | 01:06 AM
hohoho43's Avatar
yes, everything seems fine......but the weird noise is driving me nuts.....i had the mechanic checked, they all said the car is okay and they said they need to take the whole dash board out to inspect, and it takes half day and labor = $850!!!! JUST TO INSPECT!!! INSANE!
Old Sep 5, 2007 | 05:30 PM
Yes it is a major pain to remove the dash to inspect.
There is one thing I have seen happen before though.
Under the center speaker cover in the dash is a mounting tab for the dash.
I have seen the screw come loose and cause a noise similiar to what you say you hear.
Old Sep 6, 2007 | 11:37 AM
hohoho43's Avatar
Thanks Tech! I will give a try to check any loose screw. It's somewhere around the cabin air filter, do you think there is a fan? Because it's more sound like a squeezing noise from the fan......anyway, i will givea try.
Old Sep 6, 2007 | 05:36 PM
Maybe it might be from the fan but the fan is hidden really well on your car.
Also make sure it isn't the glovebox door making the noise.
Old Sep 15, 2007 | 11:04 AM
hohoho43's Avatar
It's blower motor problem on the passenger side. It cost me $250 for parts, mechanic didn't mention about labor.......i assume $500, because he said it takes at least one day. BIG PAIN! Does anyone know how to change that?
Old Sep 15, 2007 | 11:27 AM
Its not that hard. Its not an all day job!!!
swiftjustice44
Oct 25, 2012 06:32 AM
Capo Cam
Feb 23, 2008 10:19 PM
robretpd
Jan 26, 2008 02:11 PM
VW
Nov 30, 2006 05:11 PM
hohoho43
Nov 2, 2006 10:08 PM
