Where is the AC low pressure port on a 2001 Volvo S40?
Old Apr 28, 2009 | 03:45 PM
umdterps's Avatar
Exclamation Where is the AC low side port on a 2001 Volvo S40?
Does anyone know where the AC low side port on a 2001 Volvo S40? I was told it is a black or blue cap, however I noticed there are two black caps...
Thanks
Old Apr 28, 2009 | 06:58 PM
It is at the firewall back side of the motor.
Old Apr 29, 2009 | 08:29 AM
umdterps's Avatar
Hey Tech, I'm still having trouble as to what **** it is. I have attached a photo. It appears there are two similar ***** near the firewall....Which is the low side/low pressure service port to recharge the AC?
Thanks
Old Apr 29, 2009 | 09:30 PM
The low side is the one on the left side in the pic. Low side port is the smaller port of the 2. Also the high side pipe is small for higher pressure. The low side is bigger for lower pressure.
Old Apr 30, 2009 | 12:10 PM
umdterps's Avatar
Thanks Tech, I appreciate the help.
Thanks,
Grant
Old May 18, 2009 | 04:21 PM
jerryasmith's Avatar
I've got a 2006 S40 - is this **** in the same location?
The only one I can find that looks similar has a number on it, like "6 nm" or something similar.
Thanks!
Old May 18, 2009 | 09:55 PM
The one you see should be the one.
Old Jun 30, 2013 | 08:07 AM
cross plains's Avatar
Tech, To recharge the AC on my 01 s40, do I need to "drain" the system before adding additional freon or can I simply add freon to the required lb.? Thanks!
Old Jun 30, 2013 | 10:14 AM
Hudini's Avatar
Just add R134a until the bubbles in the sight glass on the receiver/dryer disappear. Lots of tiny bubbles like foam indicate a very low charge. You will notice the bubbles getting bigger as you fill until they disappear. Once the sight glass is clear STOP. It's full. In this case more is not better. Fill with the can upright too. You do not want to add liquid R1234a into a receiver/dryer system as it may damage your compressor as the fill point is before the compressor. Liquid does not compress.
al8888
Apr 27, 2013 01:14 PM
pezwack
Jul 10, 2011 08:45 PM
grand94jeep
Apr 6, 2007 03:51 PM
Rons
Jul 25, 2006 05:59 PM
Psaboic
Jun 2, 2006 08:34 PM
