Window Regulator / Motor
Old Dec 27, 2006 | 05:33 PM
02VolvoS40's Avatar
Default Window Regulator / Motor
Hey guys, I just came across this board today while lookingfor some help.[sm=shades.gif] I love these types of places, so hopefully someone can help me out. I didn't see anything under the S40 forum about this, but my driver's side window stopped working. I took it in and they said the regulator was stripped so that will have to be replaced, butthe part comes with a motor. Therefore, the whole part is $350 plus $150 for labor. I was going to look into seeing if I can do this myself and get the part for cheaper too. Has anyone done this before? If I remove the panel, is it as easy as unplugging a couple things for the regulator/motor, unscrewing the bolts, taking the old one out and putting the new one in (in reverse order)? Or is it more involved? Also, is it the same part that is on the S60, S80 and/or any of the C Series? Any feedback would be greatly appreciated. [sm=helpout.gif]
Old Dec 28, 2006 | 10:45 AM
Default RE: Window Regulator / Motor
It is pretty straight foward.
It is not the same regulator as the other cars.
What really happens is one of 2 things.
1.The cable guide breaks.
2.The inside if the motor strips out. It is plastic and designed to break it is hits something hard while the window goes up so the window doesn't shatter. Or someones arm gets broken.
Old Dec 28, 2006 | 06:15 PM
02VolvoS40's Avatar
Thanks for the response and the further explanation. So as far as fixing it,is it as easy as taking off the door panel and it's right there? Or is it inside the "shell" of the door?
Old Dec 29, 2006 | 10:10 PM
It is inside the door but pretty easy to remove and replace.
gentlejax2
May 29, 2012 11:10 AM
gentlejax2
Mar 28, 2012 06:26 AM
Ahmed
Oct 17, 2009 12:56 PM
Ahmed
Sep 29, 2008 09:31 PM
JO7
Mar 21, 2008 09:07 PM
