[02 2.4T] Climate control goes brain-dead
Old Mar 30, 2009 | 05:20 PM
skadet's Avatar
Default [02 2.4T] Climate control goes brain-dead
Every once in a while -- probably 20% of the time -- climate control goes nuts and blows what feels like full-cold air, at full fan speed, no matter what temp is set... unless I set it to max heat. Then it blows nuclear-powered heat. Usually, it works fine, but those random times that it doesn't... very annoying. Any thoughts?
Thanks,
Skadet
Old Mar 30, 2009 | 08:28 PM
Volvo is having alot of problems with the control modules and they are still trying to figure it out.
Old Mar 30, 2009 | 11:18 PM
nalonge's Avatar
I experience the same thing at times (2002 S60). I find that if I leave the climate control on when I turn the car off, then start the car a few minutes later, it will blow cold air. If I turn the climate control off before shutting the car off, then start it back up again, it works fine. It's weird like that.
Leej
Mar 15, 2021 08:28 PM
Vesitiivis
Nov 8, 2013 01:04 PM
primodevil
Mar 20, 2008 11:51 PM
92Typhoon
Nov 13, 2007 10:04 AM
