'02 s60 2.4t *not starting*
Old Dec 21, 2017 | 11:50 PM
Northie's Avatar
Default '02 s60 2.4t *not starting*
Hey everyone,
I have an '02 s60 2.4t, went to go to work this morning, car wouldn't start. I tried to boost it from another car later in the day, no change. Tonight, I tried to start it again, and took note:
Key in ignition II, dash lights cycle through, radio/climate lights on, fuel pump cycles, engine and oil light remain on.
I try to start the car: there is no sound, no crank, radio/climate lights go out, engine and oil lights remain on.
message reads: engine start prevented
Seatbelt light flash and chime sound when key returned to ignition II, engine and oil lights still on.
does anyone have any experience or information!?!?!?!!??!
​​​​​​​Thanks,
Old Dec 23, 2017 | 12:10 PM
could be the immobilizer got set. Try locking/unlocking the doors with the key fob 5x (if you don't have a fob try the same with the door key) to reset the alarm system.
Old Jul 23, 2018 | 04:54 AM
Northie's Avatar
Default Key was broken
To close this topic off, here is what happened..
I had broke the key the night before in the outside door lock because it was frozen and I couldn't unlock my door.. the next morning going to work I had the key in pliers and the car wouldn't start. I read that the key has a chip in the rubber grip that allows the car to start. So I tried my spare key and it started no issues. I then tried the broken key again reinserted into the grip part and it also worked.
thanks for the reply.
Northie
Dec 21, 2017 11:38 PM
Northie
Dec 21, 2017 11:20 PM
Suresh Kumar
Jul 23, 2017 04:13 PM
hess1809
Sep 22, 2010 03:41 PM
fmusto
Sep 7, 2008 12:04 PM
