05 2.5T awd performance
The 2.5T is a low pressure turbo design which uses a smaller capacity turbo for faster spool up (better driveability and low end torque) vs the T5s. You can find ECU tunes that will add 30-40 HP to bring the LPTs in line with the T5s. After that, you'd need a blue print to get even to 300 HP which is pricy. ie upgrade the turbo, upgrade the downpipe, upgrade the intercooler, commit to high test /93 octane. I'd consider a tune, then move on to the suspension - bigger sway bars do wonders. +1 wheels and tires next. You also may be able to upgrade to bigger brakes (say swapping in rotors/caliper carriers from another Volvo model). You can also upgrade the shocks/struts, particularly if the current have 100K+ miles. Bilstein B6s are a good upgrade here but truth is the Boge/Sachs OEMs are pretty good too. Last is the sound system. I've had tons of enjoyment from smooth, quiet cars with a premium sound system... The challenge is that Volvo went to optical connections and non standard bezel sizes in the dash unit so finding compatible after market goods may be difficult. Start with crutchfield.com to see what may fit your model.
waid302
07-05-2017 11:15 AM
