Totally confused about 2005 s80 2.5T FWD specs
Hi,
I just bought a 2005 Volvo s80 2.5T FWD. I have been trying to research specs on the net and I am totally confused. I see that there is a 2.5T AWD (and plenty of info about it), but not much, if anything on the 2.5T "Light pressure Turbo FWD". How much boost does the "Light Pressure Turbo" make? Furthermore, are there any safe bolt on turbo upgrades out there (even home-brew)? I have heard of a lot of people that have their ECM tuned for better performance, but I guess I was wondering if there are other turbo options.
FOR EXAMPLE (and pulling numbers out of the air so please don't flame)
If the stock turbo on the 2.5T FWD makes 8.1 lbs of boost then is there a source-able bolt on turbo application that would raise the boost to say 10 or 12 (even if a larger intercooler is required) to safely run with what I think is a 9:1 compression?
Before I get flamed for speaking out of turn -- I know little (nothing) about this car because it seems as if it is the illegitimate bastard child that no one on the web wants to talk about LOL.
Any help would be appreciated.
Furthermore, what would the Engine Model# be so that I could research?
Or, how do I find it out? From the VIN? Any other identification locations?
Is there even such a thing as a 2.5T FWD? According to Google there is (but no info available) When I type " 2005 volvo s80 " into Google it pops up with information and pics on the right and under "Configurations" it states:
2.5T
2.5T AWD
T6
All which are clickable links but just takes me back to the original search query. Any information would be appreciated.
Thanks and go easy on me
2.5T
2.5T AWD
T6
Here is the information that I found out about it by "decoding the VIN"
VIN:
YV1TS592451412653
WMI / VDS / VIS:
YV1 TS5924 51412653 Manufacturer:
Volvo Geely Automobile Holdings Sweden
Brand:
Volvo
Model:
S80 4DRS
Engine:
B5254T2 R5 2.5L
Transmission:
M66 / M66AWD
Region/Plant:
Gothenburg Sweden
Check:
Year:
2005
Sequential number:
12653
Approx. mileage:
165,594 km
See also
Get Vehicle Records
Get Complete VIN audit
Campaign # Report date Affected Component Recall Initiator
17/11/05 ELECTRICAL SYSTEM:STARTER ASSEMBLY:SOLENOID ODI
16/11/10 EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) MFR
03/10/06 EQUIPMENT:OTHER:LABELS MFR
18/12/09 FUEL SYSTEM, GASOLINE
ELIVERY:FUEL PUMP ODI
29/03/07 SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER MFR
Issue ID Failed Affected Component Miles City/State VIN Pattern
17/09/05 SUSPENSION:FRONT:CONTROL ARM 1652 CRESTWOOD, KY YV1TS592451
17/09/05 ENGINE AND ENGINE COOLING:ENGINE 1652 CRESTWOOD, KY YV1TS592451
Extra information on the vehicle: Name:Volvo Name:S80 Cylinder:5 Size:2.5 Configuration:inline Fuel Type:premium unleaded (required) Horsepower:208 Type:gas Code:TMP351 Horsepower:5000 Torque:1500 Gear:double overhead camshaft Driven Wheels:front wheel drive Num Of Doors:4 Manufacturer Code:184-59-32-1-9-1 Base M S R P:36365 Base Invoice:34220 Delivery Charges:695 Used Private Party:2571 Used Trade In:1828 Market:Luxury E P A Class:Midsize Cars Vehicle Size:Midsize Primary Body Type:Car Vehicle Style:Sedan Vehicle Type:Car Vin:YV1TS592451412653 Squish Vin:YV1TS59251 Year:2005 Name:2.5T Fwd 4dr Sedan (2.5L 5cyl Turbo 5A) Body:Sedan Model Name:S80 Sedan Trim:2.5T Matching Type:SQUISHVIN Highway:27 City:18
So, I guess that at least gives me a little bit of information to start with.
VIN:
YV1TS592451412653
WMI / VDS / VIS:
Volvo Geely Automobile Holdings SwedenBrand:
Volvo
Model:
S80 4DRS
Engine:
B5254T2 R5 2.5L
Transmission:
M66 / M66AWD
Region/Plant:
Gothenburg Sweden
Check:
Year:
2005
Sequential number:
12653
Approx. mileage:
165,594 km
See also
Get Vehicle Records
ELIVERY:FUEL PUMP ODI 29/03/07 SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER MFR
The VIN is
YV1TS592451412653
I used the decoder to grab info (Post pending moderator approval)
Also, from Wikipedia (cringe for using it as a reliable resource LOL) However, I am not sure what the R5 means (I am guessing the 5 means Cylinders, but I couldn't find an exact match on this page and my vehicle isn't listed as being one that has this motor (see below)
B5254T2
The B5254T2 has dual VVT and is turbocharged and intercooled. It produces 6 psi of "boost." Output is 210 hp (157 kW; 213 PS) at 5000 rpm with 320 N·m (240 lb·ft)[111] of torque at 1500–4500 rpm. The B5254T2 has a compression ratio of 9.0:1
Applications:
YV1TS592451412653
B5254T2
Applications:
- 2003–2004[112] Volvo S60 badged as S60 2.5T or S60 2.5T AWD
- 2003 Volvo V70 II badged as V70 2.5T[113] or V70 2.5T AWD[113]
- 2003 Volvo XC70 Cross Country badged as XC70 2.5T AWD
- 2003 Volvo S80 badged as S80 2.5T
- 2003–2005 Volvo XC90 badged as XC90 2.5T AWD[114]
RobCoop
1998-2000 model year V70
Feb 22, 2014 07:28 AM
