'06 S60 Factory Head Unit swap to tape deck
Old May 31, 2009 | 07:08 PM
Tommy_J_G's Avatar
Default '06 S60 Factory Head Unit swap to tape deck
Hello everyone!
Just purchased a 2006 S60 and need to listen to my ipod while i drive. I traded in my Audi A4 that had a tape player (w/ CD) factory head unit which i used to play my ipod, with adaptor that fit in the headphone jack of ipod. The 2006 S60 only has a CD player and from the research i did on this forum, there does not appear to be an easy/inexpensive way to listen to my ipod (except for the fm transmiter which sucks in my experience).
So what i want to do is swap my headunit for an older factory headunit which still has a tape deck....is this possible? Would i still be able to use the steering wheel controls? Any other opinions on what i should do?
Thanks for any advice!
Regards,
Tom
Old Jun 7, 2009 | 06:44 PM
Tommy_J_G's Avatar
Just as a follow-up, the current factory headunit is the HU-650. I also noticed when reviewing the original window sticker that the car has an optional satalite radio connection...not sure if this makes it easier to install an ipod.
thanks.
Old Jun 7, 2009 | 07:05 PM
nalonge's Avatar
I saw a post a while back about an iPod cable for your head unit. It uses the connection for the CD changer. One of the posts had the cable coming out of the pocket about the radio; it was a pretty clean install.
Here are some links:
http://www.volvo-forums.com/t4681-vo...od-adapter.htm
http://www.crutchfield.com/p_581PA11...ce.html?tp=120
Check on eBay too.
Old Dec 23, 2018 | 11:59 PM
evolvoman's Avatar
i am also having the same issue with my 2002 s60 T5, HU-613 unit.. will the steering controls work if i just give up on the tape adapter and get a pioneer after market or something?
Old Jun 8, 2026 | 08:46 AM
Fernando's Avatar
Hi
I have installed on my Volvo S60 2007 one Chinese adapter Yatour Digital Multichanger YT-M06, it works quite well
Bow To The Robots
1998-2000 model year V70
Dec 6, 2013 01:45 PM
aelancaster
Jun 10, 2013 01:27 PM
Volvo850-R
Oct 18, 2012 06:06 PM
Jumpman024
Apr 24, 2009 02:18 PM
keyul
Jan 3, 2009 11:37 PM
