12V power/cigarette lighter has no power
The fuse for this item is #13 in the passenger compartment fuse box. Pull it out to check it and, if OK, replace itand see what happens. If blown renew it.
The only other possibility is a broken wire or bad connection.
Which fuse box is the passenger fuse box? There is the one under the hood, and then one in the trunk by the tail lights on the driver's side. I don't see a fuse box anywhere else.
